Hi everyone,
I’m planning to build a multi-brand WhatsApp sales automation in n8n, and I’d like to outline the flow I’m aiming for. Any technical tips or examples would be greatly appreciated.
1. Welcome Message & Brand Selection
When a customer sends a message, the bot automatically replies with a welcome prompt:
“Welcome! Which brand would you like to continue with?
Brand A
Brand B
Brand C”
After the customer selects an option, the bot switches to the information flow for that specific brand.
2. Brand-Specific Information Flow
Once the brand is selected, the customer can ask questions such as:
Available plans/packages
Internet & roaming details
Activation process
Advantages & features
The bot responds using brand-specific documents and knowledge stored in the automation.
3. Smart Customer Profiling Step (AI-Driven)
After providing the basic information, the bot asks a few questions to better understand the customer’s needs:
“How many GB do you typically use per month?”
“How often do you travel abroad?”
“What are your daily usage habits?”
Based on the answers, an AI-powered decision layer recommends the most suitable plan.
This part also includes marketing-oriented, persuasive messaging, for example:
“Considering your monthly usage and travel habits, this plan gives you the best value while offering the benefits you need most.”
4. Purchase Flow
After recommending a plan, the bot asks:
“Would you like to proceed with the purchase?”
If the customer says yes, the automation redirects them to the online purchase page, where the selected plan is automatically pre-filled in the checkout process.
If the customer says no, the bot enters a gentle persuasion flow:
Highlights of key benefits
Value for money explanations
Quick Q&A
Optional alternative plan suggestions
5. Tech Stack to Be Used
n8n
WhatsApp Business Cloud API
OpenAI Embeddings (for brand knowledge)
AI Agent / prompt-based decision layer
Webhooks → checkout redirection
Goal
The goal is to build a stable, human-like conversational flow that can identify customer needs, recommend the best plan, and convert them into a purchase — all inside WhatsApp.
If anyone has built a similar multi-brand setup in n8n, I’d love to hear your insights or see example workflows.
