How to build custom node descriptions with recursive and flexible collection elements?
Hi everyone! :wave:
I’m working on an improved version of the Odoo node for n8n, with a modular structure and several enhancements.
I’ve already fixed the issue where search domain values were incorrectly treated as strings instead of booleans, numbers, or arrays (see forum post). Someone else also addressed this via a PR that added support for custom domain filters, based on this issue. I took a different approach but also incorporated their workaround.
Now, I’m working on improving the getAll operation to allow building complex Odoo search domains directly from the n8n UI.
Currently, filters are added as a simple AND combination:
[('name', '=', 'John Doe')]
[('is_company', '=', True)]
[('create_date', '>=', '2024-01-01')]
But I want users to create advanced, nested domains like:
    ('active', '=', True),
      ('name', 'ilike', 'Jean'),
      ('name', 'ilike', 'Marie')
    ('email', 'ilike', 'banned.com')
Odoo’s UI handles this beautifully:
This would eliminate the need for workarounds like the domain filter PR, and allow dynamic field selection based on the chosen model.
I’d still keep the raw JSON input option for power users who prefer full control.
Here’s the challenge: I can’t find any support for recursive fixedCollection inputs in n8n. Has anyone managed something like this? My current solution forces users into a rigid 3-level filter structure—unusable for simple filters and too inflexible for deep nesting.
Any tips or ideas on how to make this truly flexible?
Here is the current getAll operation part and code :
import {
	type IDataObject,
	IExecuteFunctions,
	INodeProperties,
	updateDisplayOptions,
} from 'n8n-workflow';
import {
	type IOdooFilterOperations,
	OdooCredentialsInterface,
	odooHTTPRequest,
	processFilters,
} from '../../GenericFunctions';
import { fieldsToInclude, returnAllOrLimit } from '../../descriptions';
export const logicalOperator: INodeProperties[] = [
		displayName: 'Logical Operator',
		type: 'options',
		options: [
				value: 'AND',
				description: 'Logical AND (default). Combines the next two criteria or groups. Arity: 2',
				value: 'OR',
				description: 'Logical OR. Combines the next two criteria or groups. Arity: 2',
				value: 'NOT',
				description: 'Logical NOT. Negates the next criterion or group. Arity: 1',
		default: 'AND',
export const searchDomain: INodeProperties[] = [
		displayName: 'Search Domain',
		type: 'fixedCollection',
		typeOptions: {
			multipleValues: true,
			multipleValueButtonText: 'Add Domain Search',
		default: {},
		description: 'Filter request by applying filters',
		placeholder: 'Add Domain Search',
		options: [
				values: [
						displayName: 'Field Name or ID',
						type: 'options',
						description:
							'Choose from the list, or specify an ID using an <a href="https://docs.n8n.io/code/expressions/">expression</a>',
						default: '',
						typeOptions: {
							loadOptionsDependsOn: ['customResource'],
							loadOptionsMethod: 'getModelFields',
						displayName: 'Operator',
						type: 'options',
						default: 'equalTo',
						description: 'Specify an operator',
						options: [
								value: 'equalTo',
								description: 'Equals to',
								value: 'notEqualTo',
								description: 'Not equals to',
								value: 'greaterThan',
								description: 'Greater than',
								value: 'greaterOrEqualThan',
								description: 'Greater than or equal to',
								value: 'lesserThan',
								description: 'Less than',
								value: 'lesserOrEqualThan',
								description: 'Less than or equal to',
								value: 'unsetOrEqualTo',
								description:
									'Unset or equals to (returns true if value is either None or False, otherwise behaves like =)',
								value: 'equalLike',
								description:
									'Matches field_name against the value pattern. An underscore _ in the pattern matches any single character; a percent sign % matches any string of zero or more characters.',
								value: 'like',
								description:
									'Matches field_name against the %value% pattern. Similar to =like but wraps value with % before matching.',
								value: 'notLike',
								description: 'Doesn’t match against the %value% pattern',
								value: 'ilike',
								description: 'Case insensitive like',
								value: 'notIlike',
								description: 'Case insensitive not like',
								value: 'equalIlike',
								description: 'Case insensitive =like',
								value: 'in',
								description:
									'Is equal to any of the items from value. Value should be a list of items.',
								value: 'notIn',
								description: 'Is unequal to all of the items from value',
								value: 'childOf',
								description:
									'Is a child (descendant) of a value record. Takes the semantics of the model into account (i.e., following the relationship field named by _parent_name).',
								value: 'parentOf',
								description:
									'Is a parent (ascendant) of a value record. Takes the semantics of the model into account (i.e., following the relationship field named by _parent_name).',
								value: 'any',
								description:
									'Matches if any record in the relationship traversal through field_name (Many2one, One2many, or Many2many) satisfies the provided domain value',
								value: 'notAny',
								description:
									'Matches if no record in the relationship traversal through field_name (Many2one, One2many, or Many2many) satisfies the provided domain value',
						displayName: 'Value',
						type: 'string',
						default: '',
						description: 'Specify value for comparison',
export const subNestedLogicalGroup: INodeProperties[] = [
		displayName: 'Sub Nested Logical Group',
		typeOptions: {
			multipleValueButtonText: 'Add Sub Nested Logical Group',
		default: {},
		description: 'Sub nested logical group to combine multiple filters',
		placeholder: 'Add Sub Nested Logical Group',
		options: [
				values: [...logicalOperator, ...searchDomain],
export const nestedLogicalGroup: INodeProperties[] = [
		displayName: 'Nested Logical Group',
		typeOptions: {
			multipleValueButtonText: 'Add Nested Logical Group',
		default: {},
		description: 'Nested logical group to combine multiple filters',
		placeholder: 'Add Nested Logical Group',
		options: [
				values: [...logicalOperator, ...subNestedLogicalGroup],
export const logicalGroup: INodeProperties[] = [
		displayName: 'Logical Group',
		typeOptions: {
			multipleValueButtonText: 'Add Logical Group',
		default: {},
		placeholder: 'Add Logical Group',
		description: 'Logical group to combine multiple filters',
		options: [
				values: [...logicalOperator, ...nestedLogicalGroup],
export const properties: INodeProperties[] = [
	...returnAllOrLimit,
	...fieldsToInclude,
	...logicalGroup,
const displayOptions = {
	show: {
		resource: ['custom'],
		operation: ['getAll'],
export const description = updateDisplayOptions(displayOptions, properties);
I’ve been following your improvements to the Odoo node — really impressive work on the domain filters and UI enhancements. I recently tried to tackle a similar challenge: allowing users to build arbitrarily nested, dynamic filters from the n8n UI.
You’re absolutely right — the current fixedCollection implementation in n8n doesn’t support recursion, which is a blocker for building nested structures like Odoo domains (especially with logical operators like |, &, ! in deeply nested combinations).
Here are a few thoughts based on what I tried:
:repeat: Attempted Solutions
1. Multi-level fixedCollection nesting (like you’re doing)
I also hit the same limitation: it’s okay for 2–3 levels max, but becomes unmanageable for real-world cases. UI complexity explodes quickly.
2. Fallback to JSON input for power users
I ended up exposing a json field as an alternative input (type: json, typeOptions: alwaysOpenEditWindow) and validating the domain with custom code before sending it to Odoo. Not ideal UX-wise, but necessary for full flexibility.
3. UI with code preview sync
I’ve been experimenting with a hybrid interface: a visual builder that generates the JSON in real time and allows editing the raw structure directly. This could be done with an external React form or web UI (hosted elsewhere), launched from n8n via an iframe link or modal input field.
:construction: Suggestions / Open Ideas
  • Unfortunately, I haven’t found a way around the recursive input limitation within native fixedCollection. It’s a hardcoded UI constraint in n8n.
  • What could work is a “flattened” representation: a linear list of logical operations with parent-child metadata (like depth or groupId). Then rebuild the nested domain structure in code before sending to Odoo.
Let me know if you want to explore that hybrid JSON + UI builder idea — I’d be glad to share a basic prototype I used for a different use case with nested filters.
Thanks for the input.
I pushed my changes on the Odoo node upstream. Hope it helps somehow.
In any case, if you find a better solution than the JSON input I ended up doing (from @cgsmith PR and changes), feel free to add an update !
I won´t be using n8n for Odoo anymore so I won´t be working on that anytime soon unfortunately.
