How to call a trained LORA?
Hey, i have trained a lora ( Image to image ) using fal-ai/flux-lora-fast-training and i have the trigger word as well say, trump.
I have the lora config file and the diffuser lora file. I cant see any tutorials on youtube about it even GPT isnt helping out & i am having a hard time in calling the trained lora?
i dont know how to call it.
Q. can i use different image-image model to use that lora? say nano-banana or any other image to image tool?
Q. i actually want to call it in n8n & i have no idea what the URL should be in the HTTP request node and what body shall i send and what parameters should be sent with them?
if anyone call help me out would be much appreciated - i am ready to answer any further questions as well
n8n successfully outputs it but in fal the error code is 422
nothing much in the workflow as i am testing it at the moment
its a manual trigger
Hi @shaheer_riaz
This is a simple example workflow for calling nano-banana using fal.ai
Feel free to use it as a guide to understand how things work in Fal,
There are many options available, I recommend reading the Fal documentation for more details for each model..
thanks
but the problem is different
i can call basic nodes easily in n8n
i have trained a LORA in falai
and theres a problem with that when i call it in n8n
→ image url; if i upload it to drive theres an issue with it fetching the image
→ if i read the file and convert it into base64 then theres an issue
( http request nodes body is messing up as i have to share the path for the trained LORA but the image URL is the main thing
As far as I know, the image link needs to be public,
You can also host your images on S3, for example.
What is the issue?!
Attach your workflow showing the specific error/output, maybe someone will be able to help..
