I have a standalone code node that acts as “reuseable javascript function”. How to call and pass data to this node programatically to gets its return value from any other code node which need that?
n8n version: 1.33.1
Database (default: SQLite): SQLite
n8n EXECUTIONS_PROCESS setting (default: own, main): default
Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
Operating system: ubuntu
n8n
March 30, 2024, 4:36pm
2
n8n version:
Operating system:
Either copy and paste it, whenever you need it, or add it to a separate workflow with the trigger execute workflow and call it with execute workflow.
…or create a custom node.
system
Closed
June 28, 2024, 4:58pm
5
