Hello! When using $workflow.active
, its value is always false
even though the workflow is active. Why is that? After a certain delay, I need to check if the workflow is active.
- n8n version: 1.55.0
- Database (default: SQLite): PostgreSQL
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Running n8n via (Docker, npm, n8n cloud, desktop app): npm
- Operating system: Ubuntu
