Hi guys! I’m in a project that i need consume some data from tables in AWS Athena and create a workflow on n8n.
Is there any way to make this connection? Any alternative?
I appreciate any and all help!
Hey @gfrts,
Welcome to the community
I have not used Athena before but assuming it has an API you might be able to use that with the HTTP Request node, Does Athena have anything clever in it like the ability to connect using MySQL clients? That could be another possible option if it is supported.
I managed to install the SDK using the command node with the following code: cd /root/.n8n && npm install -g aws-sdk
To do a get or a post, I run a code node with the following code:
`NODE_FUNCTION_ALLOW_EXTERNAL= ‘aws-sdk’
var query = $node.Webhook.json.body.query
const AWS = require(‘aws-sdk’);
AWS.config.update({
accessKeyId: ‘KEY_ID’,
secretAccessKey: ‘SECRET_KEY’,
region: ‘us-east-2’
const athena = new AWS.Athena();
const params = {
QueryString: query
function waitForQueryCompletion(queryExecutionId) {
return new Promise((resolve, reject) => {
const checkStatus = setInterval(() => {
athena.getQueryExecution({ QueryExecutionId: queryExecutionId }, (err, data) => {
if (err) {
clearInterval(checkStatus);
reject(err);
} else {
const status = data.QueryExecution.Status.State;
if (status === ‘SUCCEEDED’) {
resolve();
} else if (status === ‘FAILED’ || status === ‘CANCELLED’) {
reject(new Error(Falha na execução da consulta. Status: ${status}
}, 100); // Verificar a cada 2 segundos
async function runQuery() {
const queryExecution = await athena.startQueryExecution(params).promise();
const queryExecutionId = queryExecution.QueryExecutionId;
try {
await waitForQueryCompletion(queryExecutionId);
console.log(‘Execução da consulta concluída.’);
// Obter os resultados da consulta
const getResultParams = {
const queryResults = await athena.getQueryResults(getResultParams).promise();
// Preparar o array de objetos de saída
const arrayDeObjetos = queryResults.ResultSet.Rows.map(row => {
const objeto = {};
queryResults.ResultSet.ResultSetMetadata.ColumnInfo.forEach((coluna, index) => {
objeto[coluna.Name] = row.Data[index].VarCharValue;
return objeto;
return arrayDeObjetos; // Retornar o array de objetos
} catch (error) {
console.error(‘Erro:’, error);
return ; // Retornar um array vazio em caso de erro
const saída = await runQuery();
return saída; // Isso será retornado como a saída do seu código no n8n`
Does this mean that you’re installing aws-sdk on each run? Or are you self-hosting and just have it installed so that it’s available on the cmd line?
Would be curious how to work with this as well, we’re on the n8n cloud service.
It’s running self-hosted, the workflow I created checks if the package is available, if not, install it again and run the query.
