How to connect dbt MCP with n8n?
:waving_hand: Hi everyone,
Has anyone tried connecting dbt MCP with n8n?
I’ve seen some discussion in the dbt community, but I couldn’t find n8n-specific documentation. A few things that came up in that thread:
  • n8n’s built-in MCP client currently only supports the deprecated SSE protocol, while dbt MCP requires streamable HTTP.
  • Two possible workarounds mentioned:
  • Setting the environment variable N8N_COMMUNITY_PACKAGES_ALLOW_TOOL_USAGE=true is necessary to get the MCP server working as a tool.
  • Headers in n8n flows need to be configured carefully (one per line, with key=value format).
Where I’m stuck right now:
  • I can connect and list tools, but I run into errors when trying to call specific ones like text_to_sql. It seems n8n isn’t always passing the right payloads to MCP tools by default.
  • Some folks suggested manually specifying tool parameters, but that feels brittle.
:backhand_index_pointing_right: Has anyone here managed to get dbt MCP tools working smoothly in n8n? In particular, how are you handling tool payloads like text_to_sql?
Would love to hear if others have tried this, or if there’s an easier way to set it up. Thanks in advance!
