How to Connect SAP to n8n in Minutes
VIDEO:
:rocket: Tired of complex SAP integrations? We get it β€” connecting SAP to modern automation platforms can be painful. That’s why we built the NeKu.AI n8n SAP Connector β€” a simple, secure, and powerful way to connect your SAP system to n8n. In this video, we walk you through every step: :white_check_mark: Installing the n8n SAP Connector :white_check_mark: Setting up secure credentials :white_check_mark: Running SAP reports directly from your workflow :white_check_mark: Sending and receiving data using JSON payloads :white_check_mark: Testing with real examples like MaterialType and MaterialStock reports :light_bulb: With the power of NeKu.AI, SAP integrations are now faster, safer, and smarter. You can even view live stock quantities, process material data, and manage reports β€” all from your n8n interface. No more complex setups. No more limitations. Just one connector β€” endless possibilities. :blue_book: Resources: :link: GitHub Repository & Documentation β†’ https://github.com/nekudos/n8n-nodes-sap :envelope_with_arrow: Need setup support? Contact us: [email protected] :globe_with_meridians: Learn more: [https://neku.ai](https://neku.ai) #NeKuAI #SAP #n8n #Automation #Integration #AI #WorkflowAutomation #SAPIntegration #DigitalTransformation #EnterpriseAI
