I tried to add X but every time I add the key I try to connect my account and get an error. Am I adding the wrong key?
I regenerated them to use but maybe I’m using the wrong ones.
Hi @Adam_Khdair ,
If you have using Token it will get expired so confirm you should use API Key and Secret.
I just made new ones and its still doing the same thing.
