How to count values and summarize a values on all items
I am trying to build a report which sum all the values on a specific field and create a counter of that.
kind of Group by and count in MySql.
for example
    "recommendation": "CHALLENGE"
    "recommendation": "DENY"
the node will generate the following output
  "DENY": 2,
  "CHALLENGE": 1
what would be the easiest way to do it?
  • **n8n version:1.25.0
  • **Database (default: SQLite):Postgres
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):Docker
hello @mtubul
you can do that with the Summarize and Code nodes
You can use summarize node like this without any additional code
That’s why the code node is needed :slight_smile:
The data outputs in the different format than requested
    "recommendation": "CHALLENGE",
    "count_recommendation": 1
    "recommendation": "DENY",
    "count_recommendation": 2
Thank you very much, working like a charm
