Good Evening,
I need to count the words in a given JSON String:
“Text”:“This is a sentence”
I already searched around but didn t found anything I can use. Maybe somebody can point me in the right direction on how to do this in n8n.
Thanks
Bln
Good Evening,
Thanks
Bln
I played a little bit around with the code node and the following script
var wordCount = 0;
var key = "Text";
for (const item of items) {
if (item.hasOwnProperty(key)) {
var value = jsonObject[key];
// Check if the value is a string
if (typeof value === 'string') {
// Split the string into an array of words
var words = value.split(' ');
// Add the number of words in the string to the word count
wordCount += words.length;
return [
json: {
wordCount
But somehow it is not working well, I always get 0 as an answer.
The input to the code node are multiple Items containing the Key “Text” and then the text itself.
The most simple version would be the following expression:
{{ $json["Text"].split(' ').length }}
works perfectly, Thanks a lot jan!
Glad to hear that it was helpful. Have fun!
