How to create a counter or increment system on n8n?
Hello everyone! :star2: I hope you are well. Today, new video on n8n where we will discover how to create a counter or increment system. This concept may seem complex at first, because n8n does not have a built-in increment system. However, it is essential when you want to make loops that increment a variable by 1, 2, 3, etc. Don’t panic, I will show you how to set it up easily!
:mag: What you will learn:
Why n8n does not have a native increment system.
How to create an increment variable.
Use loops to increment this variable at each iteration.
Practical example with a workflow.
A big thank you to our active Discord community member for sharing an awesome template that helps us in this demonstration. :bulb: Join us on Discord for more tips, workflow sharing and answers to your questions!
Ps : This video is in French, please use YouTube auto-translate for English subtitles
Thanks for this!
@Jeremy_DE_CAMPOS
I wish this was in english! This is a good problem to solve. Do you happen to have the workflow that you can share?
Best,
Robert
Hi Robert,
here is a workflow of an increment counter, hope that helps.
It works perfect, thank you!
