Hi there,
Looking to know if anyone has being cappable to use the Chat Trigger Node connected to more than one.
Hello everyone!
I’m trying to build a chat flow in n8n that involves multiple AI Agents (for example, 3 different AI Agent nodes), each of which should only be triggered after the user has completed a task or conversation with the previous agent.
What I’m Trying to Achieve
- I have a Chat Trigger node that receives user input.
- I want AI Agent 1 to handle the first step, then wait for the user to confirm or complete something.
- After that confirmation, AI Agent 2 should start, and only then AI Agent 3 should run.
The Problem
- Currently, when I connect the AI Agent nodes in sequence, they all fire automatically one after another. It seems like the next agent is being triggered immediately instead of waiting for a user confirmation.
- This leads to the agents “talking over each other” or receiving responses as if they were the user.
What I’ve Tried
- Connecting the nodes in a simple linear sequence (AI Agent 1 → AI Agent 2 → AI Agent 3).
- Attempting to insert an IF node to check if the user has typed something like “Ok, next step” to move on, but I might be missing something in my setup.
- Looking into storing a “state” variable in Simple Memory, but I’m unsure how to make the flow pause and wait for the user’s next message.
What I Need Help With
- How do I structure my workflow so that AI Agent 2 only runs after the user explicitly finishes the conversation with AI Agent 1?
- Is there a recommended pattern for using Wait or IF nodes with Chat Trigger flows so that the next agent only fires upon a specific user response?
- Any best practices for managing “state” or “step completion” across multiple AI Agents in n8n?
