Can I create AI agent using Alibaba LLM? I am able to call the Qwen-plus by using http request. However, I dont know how to set up with AI agent node. Anyone try before and how to do the setting in n8n AI agent node particually in the model setting. Thank you.
If “Alibaba LLM” is an OpenAI-compatible API which I guess it is, then you can use the AI Agent node with OpenAI node credentials after editing the Base URL here with the endpoint for Alibaba:
You can create an AI agent using Alibaba’s LLM (Qwen) by using Alibaba Cloud Model Studio / DashScope API. First, create an Alibaba Cloud account, enable the Qwen model, and get your API key. Then use the DashScope SDK (Python or Java) to call the model, define system prompts, and add tools or memory logic if needed. For advanced agents, you can integrate Qwen with frameworks like LangChain or build custom workflows around the API.
