Hi there!
I’ve been trying to build a workflow which create an opportunity in Affinity from data in an Airtable table.
- Node “New Airtable row” : sucessfully take the data I entered in Airtable
- Node “HTTP request” : goes into affinity through the API key to see if the opportunity already exists by looking if the website is matching
- Node “Error branch” : if the opportunity already exists, it goes back to the airtable to check a box “Already exists in Affinity”
- Node “Create an opportunity” : create an opportunity if it does not already exist → not working
Here are the details of the nodes :
Any advice is very welcome!
