I would like to hide the “Advanced Ai” section and all the nodes under this section. how should i do it? see image attached
n8n version:
**Database (default: SQLite):postgres
**n8n EXECUTIONS_PROCESS setting (default: own, main):default
**Running n8n via (Docker, npm, n8n cloud, desktop app):container
Operating system:
n8n
May 20, 2024, 9:20am
2
n8n version:
Operating system:
Hi @mtubul
it is currently not possible to disable that section and all the nodes in it.
Why would you like to hide that section and the nodes?
We using it as hosted version, since we now preferred not support this capability i thought just to hide like excluding other nodes.
Thanks for the feedback @mtubul
I get your point. What is the problem of having those nodes and the section available on the nodes panel?
mtubul
May 20, 2024, 10:32am
6
We thought to prevent from our customers to use it in advance and in case we would like to enable it, to open it via a configuration. disable it after a customer using it might be more complicated.
Ok great thanks for the feedback!
system
Closed
May 27, 2024, 10:34am
8
