How to download csv file from slack using Read Binary Data
I want to run a workflow like this:
File upload to slack channel → Slack Events API sends trigger to n8n webhook → n8n Workflow starts → Read binary file uploaded to slack → convert into spreadsheet → remaining workflow
I have setup everything except this:
Please share the workflow
  • n8n version: 0.220.0
  • Running n8n with the execution process [own(default), main]: main
  • Running n8n via [Docker, npm, n8n.cloud, desktop app]: Docker
Hi @kp-kun-dip!
The ‘read binary file’ node is just for reading a file from the local filesystem, so you don’t need it here.
Have a look at the Spreadsheet file node, which you can use to convert the binary file you get from Slack into JSON that you can process in subsequent steps.
