How to config the quickchart node to draw the two time series in the sample data? Thanks!
Hey @Kemaru Welcome to the community!
Unfortunately, the QuickChart node mangles the json when you try to add anything other than an array. Answer is to really just use the HTTP request node and hit the API directly.
