How to enable audio transcribing using Z API?
Hey @Soho hope all is well.
Would you like to expand on your question a little bit, explain the setup and specifics of what isn’t working for you? What do you need to transcribe, what are the inputs and expected outputs etc.
Hey, please check this template as a starting point, so you can test and reuse stuff. Also check out the others with audio transcribe in the name:
Also, you can import the z-api community node which provides ready nodes for some operations:
Hope it helps!
