How to get a token for a long lifetime fb page?
Thank you very much. I’m going to check it out with myself.
Wyniki tłumaczenia
"I have just done a bit of troubleshooting for you, If you use the Facebook Graph Explorer and tell it you want to get the data for / 100075258373881 / accounts do you see the same response and a warning? I have tried using my ID and I get this… " Should I do this first part for the user token? As I understand correctly, I should put in something like “/ 100075258373881 / accounts” and check if a message pops up like in the picture, but unfortunately it did not pop up. I checked if I have this “pages_show_list” item selected and checked.
I have created tokens several times (more than a few). So I created a new test page to check if facebook blocks the first one. when creating a Long live page access token for the other side, it displayed something like this: (# 100) Tried accessing nonexisting field (accounts) on node type (Page) "
Hello, I spoke to facebook. before I get the token I need, I first need to get User Access Tokens. I can do it via this link Login-Vorgang manuell erstellen - Facebook Login - Dokumentation - Facebook for Developers. will you help me implement it? it will probably be useful to others as well.
Hey @Max_T,
I can have a look at some point but I am not sure when it will be, in theory there is enough in this thread to work it out from.
If it is urgent we do have an experts program where we have partners who deal with creating workflows for those that need them.
Hey guys, so i ran into this same problem. I dont know what the issue is but all the FB documentation provides a blank array.
what did work for getting it, is get your user access token, then in the graph api tool i used my page’s id name and then the query
https://graph.facebook.com/v19.0/yourpageslug?fields=access_token
I dont remember how i found it, but it gave me the id i needed. I put it into the debugger and clicked extend. So hopefully this works for a while
This wf gen long lived page token, with inputs: short lived user token, client id, client secret.
Hope this helps!
