How to get Deep Seek reasoner model to work without Function calling error
I currently have a workflow that works (I’m using Chat GPT o1 model currently) but I’d like to swap it to Deepseek r1 as it’s much cheaper. See below, the current working one.
When I try to use DeepSeek R1 model instead I get an error saying I can’t do function calling.
I’m not exactly sure that I’m doing any function calling so I’m not too sure what to do. I know that I need a reasoning model (o1 or r1) as there’s some math involved, because when I try to use chat model or gpt-4o, they give me the wrong outputs.
Does anyone have any ideas on what to do to get DeepSeek reasoning model to work?
Any advice is appreciated :slight_smile:
Hello !
As you don’t need tools, you can just use the basic LLM chain node :
Hope this helps ! :slight_smile:
@lugnicca
Ohhh now I understand.
Thanks so much!
