How to handle Slack modal submission events in n8n without hitting a timeout?
I’m trying to handle Slack modal submissions within n8n. I can open the modal successfully from Slack (e.g., via a slash command), but when the user submits the modal, Slack sends the view_submission event to my Interactivity Request URL. I’ve configured this URL to point to an n8n Webhook node. The issue is that Slack expects a 200 OK response within about 3 seconds. If my workflow does more complex processing, Slack times out and returns a “curl error timeout.”
What I’d like to achieve is to immediately acknowledge the submission in n8n by returning 200 OK to Slack, and then continue with the heavier processing after the initial response. Once done, I can send a follow-up message (using chat.postMessage or a response_url) to the user.
Has anyone managed a similar setup in n8n? Any best practices or examples would be highly appreciated!
“curl error timeout” from Slack.
(Select the nodes on your canvas and use CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow here.)
No specific output at this stage, just the timeout error.
Welcome to the community @_Park !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
If you do not need for the model to be open while you process the submitted data, then do just that - respond to view_submission immediately, Modals | Slack.
