Hi community! I am having a small issue. most of my flows are executed by a single call to a webhook node. I then do some basic transformation and use execute workflow nodes to pass the data and trigger other flows for different use cases.
I have been having issues while creating this flows cause I can´t find a good way to build and test using the data structure that would come from the execute workflow nodes. I currently use postman to hit the test endpoint with a fake webhook node I later eliminate.
Is there a way to initialize the data for the trigger node without having to hit the endpoint? Example, I take an execution of the main flow, grab the JSON that gets sent to the execute node, paste it in the start node of the next flow, and use that as an initialization until it is active and receives the actual data from the workflow?
I would typically use a Function node to mock incoming data without an actual webhook. So disabling the webhook and adding a Function node with code like this should do the trick:
