How to integret hugging face
hi guys can you help me to understand how to integret hugging face in n8n i try to put the curl but i don’t no where the problem i face this problem “Your request is invalid or could not be processed by the service”
Hey @Kamal_Ait !
The cURL command can be imported into the HTTP node if you click the button :
Hi @Kamal_Ait, Welcome!
You can use it directly in an HTTP node like this:
Or you can add the base URL as an OpenAI-compatible endpoint in the OpenAI node like this:
i know but i think the problem maby in hugging face curl or the model use it. but thanks for reply
thanks Brother
