How to issue tamper-evident verifiable certificates from an n8n workflow (2 ways: node or plain HTTP Request)
A question that comes up here now and then: “how do I generate/issue certificates to my users from a workflow, and make them actually checkable — not a photoshoppable PDF?” Sharing a small tutorial in case it saves someone time. Two ways, pick whichever fits — no account signup needed to try either.
What you get: each certificate gets a permanent public verify page with an Ed25519 signature, so the recipient (or whoever they show it to) can confirm it’s genuine and unaltered — unlike a PDF, which anyone can edit.
Option A — the community node (n8n-nodes-attestify)
  1. In Settings → Community Nodes → Install, add n8n-nodes-attestify (verified node, searchable in-app).
  2. Drop the Attestify node into your flow after whatever event should mint a cert (course completed, form submitted, deal closed).
  3. Set issuer + recipient name/email + the credential fields → run. The node returns the cert id and the public verify URL.
Option B — no install, just an HTTP Request node (30-second version)
If you’d rather not install a community node, one core HTTP Request node does it:
  • Method POSThttps://attestify.novadyne.ai/cert/issue
  • Body (JSON):
  "issuer": "Your Academy",
  "course": "Advanced Workflow Automation 2026",
  "recipients": [{ "name": "Jane Doe", "email": "jane@example.com" }]
Checking a cert is just opening its verify URL — the page reads the authoritative signed record and shows Verified + the details, or flags a mismatch.
Full disclosure: I work on Attestify (it’s the tool in both options). Happy to answer questions on either approach, or on wiring it to a specific trigger.
