How to iterate over JSON (AI Structured Output)
How can I iterate over the output from “Generate article plan” It returns structured output which looks like this
    "output": [
        "name": "Title",
        "description": "Steamy Car Windows: Hot vs Cold Air – What Works Best?"
        "name": "Introduction",
        "description": "Some text here."
And for each of this “section” from output I would like to run “Generate section” agent, save to Aggregate and then run go to the next item.
I don’t know how to do it.
  • n8n version: 1.72.1
  • Database (default: SQLite): No database
Welcome to the community @Kacper_Wlodarczyk !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
Do you also want to aggregate after all the items have been processed by AI? If so, your “Generate Section” needs another Aggregate node connected to “done” as in screenshot below.
