How to know what other informations are store in Json for workflow and execution
I want to know how we can learn more about the additional JSON information stored in the workflow and execution nodes. For example, with $json["workflow"]["name"] and $json["workflow"]["id"], we can fetch more information about the name and ID of the workflow. However, what if we need to know about other information, such as the URL?
Similarly, with $json["execution"]["id"], we can learn about the execution ID. But how can we access other information?
NO
No workflow
any document or example which we can follow.
Hey @Gouravdev,
There is no option for the URL that I am aware of but you could easily generate it as the URL would just be https://n8n.yourdomain.tld/workflows/{{ $workflow.id }} or to get fancy {{ $env["WEBHOOK_URL"] }}workflow/{{ $workflow.id }}.
I don’t think we document all of these options yet but the autocomplete should give you the options available.
Thanks @Jon
I have tried the same for the URL but the aim is to get to know more about other information of node JSON. I will check and update soon.
Please if possible document somewhere so that we can follow that one in future.
