How to log traveling information from Elevenlabs using Edit Field module?
Hi All
I have a travel agent workflow , it work with elevenlabs , i want to use edit field module to log the data : -
I try to capture below information at Edit field module :-
Departure Date
Return Date
Dep Location
Arrival Location
Name
Email
I wanted to capture the above field info at Edit Field Module , using the Pin approach , now all field capture data are null :-
Can some one share with me it there a way capture the data ?
As i don’t know when Elevenlabs will send to data to Edit field module ?
The reasons i need to log the data , is because i don’t need to keep testing using my credit from elevenlab while i doing testing my workflow.
Remark :- for workflow input telegram , i am able to log it. but not above workflow.
Paul
Hi @Paul_Yeo,
Please run the Webhook node first so that it generates an output. Then, use that output as input for the next node and pin it.
@mohamed3nan
Many thank for your sharing.
My issue is when i try to log data at webhook module , i am unable to get the data. you can see that below screen is i am doing log the data , while i am talking to Elevenlabs : -
unlike for telegram input , when i send the massage i can see the first module is activate and running. But for elevenlabs , i don’t know when the data will come in ?
it there a way i can create a module to block the data , and i can log it .
Paul
@mohamed3nan Just to update . I replace with form submission module . It work fine now. Thank you @mohamed3nan for alway help me .
So case close
Paul
