How to merge rows with same data
Is there a possibility to merge the same data into one row but keep other data separate?
Example:
This is simplified
to this:
JSON example:
“Task”: “123”,
“Date”: “2024-11-14 09:51:00”,
“User”: “Jake”,
“Client”: “Shop”,
“Code”: “111”,
“Action”: “Installed”,
“Serial number”: “12345.”,
“Task”: “123”,
“User”: “Jake”,
“Client”: “Shop”,
“Code”: “222”,
“Action”: “Removed”,
“Serial number”: “54321.”,
  • **n8n version: 1.56.2
  • **Running n8n via desktop app
  • **Operating system: Windows
Welcome to the community @Nikol !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
What you are asking for implies JSON with an array of sub-data as one of the properties.
That is it mean aggregating the data in some way. For example, your original data
    "Task": "123",
    "Date": "2024-11-14 09:51:00",
    "User": "Jake",
    "Client": "Shop",
    "Code": "111",
    "Action": "Installed",
    "Serial number": "12345"
    "Task": "123",
    "User": "Jake",
    "Client": "Shop",
    "Code": "222",
    "Action": "Removed",
    "Serial number": "54321"
would be converted to
    "Task": "123",
    "User": "Jake",
    "Client": "Shop",
    "Code": [
      "111",
      "222"
    "Action": [
      "Installed",
      "Removed"
    "Serial number": [
      "12345",
      "54321"
This could be achieved in the way demostrated in the workflow below.
Thank you for your answer
