I think this is an extremely basic function that I can’t find on n8n: how to pass secondary data through a node, without it being processed?
Example of a concrete situation: the trigger receives several data (the photo of an expense report + a short explanatory text + a phone number).
The first node that I position in output of the trigger is an OCR node (Tesseract: perfect!). It extracts the data from the photo (the “main” data in this node) then sends it to the AI agent that follows and will process it (to retain only the essential data and format it in a usable Json).
But in the meantime, what happened to the “secondary data” (text accompanying the photo and the phone number)? This data remained on the trigger. It would have been so much simpler if the nodes had integrated by default an option “pass the data without processing it”. What I would have activated on the OCR node for example.
Instead, you have to tinker with other nodes, like “merge” that you will put above and that will retrieve the data from the trigger and the OCR. But if it were just that, it would still be fine: the output of this “merge” generates a big indigestible Json in which the AI can no longer find its little ones (no prompt, however refined it may be - generated by AIs - has managed to correctly extract the Json output of the “merge”).
Perplexity told me about a feature called “passthroughtData”. But it is unable to tell me how to execute it or find it.
Unless I missed something?
If anyone has an idea?
In my workflow, I would need to pass secondary data through nodes almost all the time without it being processed or lost. Wouldn’t this be a good option to include in a future update?
- n8n version: 1.79.3
- Database (default: SQLite):
- Running n8n via Docker:
- Operating system:
