Would like to read input payload submitted to wobhook in workflow 1 when Error Trigger workflow start
i.e I am submitting request to workflow 1 which perform business logic and encounter error and then send error to Trigger flow.
During error flow I would like to read entire payload or key part of input request in error flow and then send error and payload to slack
- Database you’re using (default: SQLite):
- Running n8n with the execution process [own(default), main]:
- Running n8n via [Docker, npm, n8n.cloud, desktop app]:
