Hi,
I’m sending an http post request, and am receiving the message "ERROR: The data in “Body Parameters” is no valid JSON. Is there a way to see the full JSON that was sent in the instance? I can only see the first few characters in the body parameters field when opening the failed execution.
Thanks krynble, that makes sense, but since n8n doesn’t accept the json that I’m sending, it doesn’t even initiate sending it, so nothing arrives. I don’t understand why postman accepts it without problem and everything arrives at the destination application without a hitch, but in n8n it doesn’t work. And it’s not because of parameters, the part that causes the problem is this one:
“interacoes”:
{“0”:
“tipo” : “L”,
“descricao” : “Lead em recuperação - remarketing”
