How to set execution tags
There is an option in list of executions to filter by “execution tag”, but I don’t see a way to set them. I’m searched and asked the AI agent, and I’ve come up empty. I think it would be helpful to be able to filter executions by tags, but I don’t see a clear way to set them.
Hi @origin8
If you’re asking about an automated way to add tags, AFAIK it’s not possible ATM,
So you have to go to the execution and add the tags manually:
However, there is a built-in node called Execution Data that allows you to add custom key–value data, and you can see them in the upper right corner of an execution page:
