Hi - I have some long-running workflows that keep running “in the background”. After they’ve started running, is there a good way to stop them? Turning off the “Active” state does not work.
Btw I’m on 0.135.1
Thank you very much!
Btw I’m on 0.135.1
Hey @Byron,
You can stop the workflow from the Execution List. If a workflow is running, in the Executions list you will see the button to stop the workflow. That should stop the running workflow. If it gives an error, it might be because your n8n instance crashed and you will have to restart it.
Works! Amazing, thank you!
