How to test custom node credentials with custom test function?
Hi! I am new to node development, I am building a programmatic style node that connects to an Oracle database. My credentials need to be tested with a custom function. I have declared a credentials object in the .node.ts file like this:
credentials: [
                required: true,
                testedBy: 'testConnection'
I’ve declared this testConnection function in the node’s methods object like this:
methods = {
        listSearch: {
            searchTables
                //the credential test function is declared here:
        credentialTest: {
            testConnection /** this function exported in and imported from another file */
My test function adheres to the ICredentialTestFunction interface by n8n, returning a promise of INodeCredentialTestResult
Yet I keep getting the ‘No testing function found for this credential’ error when testing the credentials.
Am I doing something wrong?
  • n8n version: 0.210.0
  • Default SQLite database
  • Running n8n via Docker
Hey @lucianblignaut,
Welcome to the community :raised_hands:
An Oracle node is going to be fun as it would typically require an oracle binary on the image to work but I like what you are trying to do :slight_smile:
Normally we see that message when there is a typo somewhere, As a quick test it might be worth doing a copy of the connection test code into that method just to see if changes anything.
