How to track workflow events using metabase? Any one using metabase?
to build a custom dashboard. planning to use metabase, if anyone currently using it. please share
howz your experience and how you setup tracking and monitoring events.
Metabase is a great tool for building custom dashboards and tracking workflow events. You can set up tracking by integrating Metabase with other tools using n8n, which allows you to automate workflows and transfer data seamlessly. For example, you can use n8n to connect Metabase with PostHog or Salesforce for event tracking and monitoring, as detailed in [n8n.io](https://n8n.io/integrations/metabase/and/posthog) and [n8n.io](https://n8n.io/integrations/metabase/and/salesforce). This setup can help you visualize and analyze workflow events effectively.
