How can I generate this link?
Generate audio node:
HTTP request node (Send video):
Workflow:
The API I use only accepts URLs
I understand. I suppose you have to upload that file into a publicly accessible URL and use that exact URL as a parameter. The easiest approach would be the one I did before: using tmpfiles.org API
What you have to do:
Add an HTTP Request node between your ‘audio generation’ node and the ‘send video’ node where you have to address the file
Set the node as follows:
Method: POST
Params: file= {{ $binary }}
The output of this request that will be sent will be a publicly accessible URL of the file you uploaded. Use this URL as a parameter in the next node under the name ‘audio’
Note: This URL is only temporary (duh). If you wish to work with a specific file for a longer time I recommend searching for external apps that offer file upload. Or if you are self-hosting then you are able to use a Docker image of your own for safety.
free and easy way would be upload to google drive and use that.
Thanks for the help, I solved the problem, just convert to base64, I discovered that the API I use accepts base64 as a response.
