How to update N8N_PAYLOAD_SIZE_MAX variable on AWS ECS hosted n8n
How Do I update N8N_PAYLOAD_SIZE_MAX variable when I am using n8n via docker on AWS?
I tried to change another variable (EXECUTIONS_PROCESS to main) by adding the variable in task definitions on AWS ECS where n8n is deployed.
When I did the same with N8N_PAYLOAD_SIZE_MAX, it does not work.
I practically tried working with file sizes from 2KB to 30MB.
It crashes exactly when file size crosses 16MB (default value for N8N_PAYLOAD_SIZE_MAX)
Task definitions is not the place to add N8N_PAYLOAD_SIZE_MAX variable?
Hey @kp-kun-dip,
You would set the environment option wherever the other options are set, did you follow any specific guide when setting up n8n?
@Jon
It works now!
I had to increase the spec of my container task after updating N8N_PAYLOAD_SIZE_MAX in task definitions.
