In my workflow I made it to extract a zip file and then sort filename in alphabetical order. How do I upload the first file after it’s been sorted cause file_0 is no longer the first file so I don’t know which file_x is the the first file.
- n8n version: 1.123.16
- Database (default: SQLite):default
- n8n EXECUTIONS_PROCESS setting (default: own, main):default
- Running n8n via (Docker, npm, n8n cloud, desktop app):npm
- Operating system: Windows Server 2022
