How to use 'build with AI'
I am currently on a 14-day trial, using n8n version 1.116.2. I want to use the “Build with AI” feature to create workflows, but I cannot find this option on my interface. Is this feature unavailable for trial users, or are there other reasons?
There is no error message. The “Build with AI” feature is simply not visible or missing from the UI. Specifically:
When I click the “+” button to create a new workflow, I do not see the “Build with AI” card/option.
I also cannot find a dedicated AI Assistant button on the canvas.
Not applicable, as the issue is about a missing feature preventing workflow creation.
Not applicable.
Additional Information:
n8n Version: 1.116.2
Deployment: n8n.cloud
I have already checked:
Settings > License: My license is active and in the trial period.
My expected outcome is to see and use the “Build with AI” feature to generate workflows automatically.
Maybe try to add this in your chrome devool console
featureFlags.override('043_workflow_builder_release', 'variant')
But you should already see that anyway.
