How to use multiple web hooks in single point
When I use Webhook1 I’m getting error
ERROR: The node “Webhook” hasn’t been executed yet, so you can’t reference its output data [Line 8 | Item Index: 0]
In Completed_Activity Function I’m getting error
const value;
if($node[“Webhook”].json){
value=$node[“Webhook”]?.json;
return value;
if($node[“Webhook1”]?.json){
value=$node[“Webhook1”].json;
return value;
Hey @AMS_KHADHIRI,
That error makes sense to me, It won’t exist if it has not yet ran. What I tend to do for things like this is pop in a NoOp node then I can just use $node["webhookData"] and it will contain the data from whatever webhook happened to run.
