How to use Olama to implement a Rag Q&A system?
My computer system is Win11, and I have deployed n8n locally using Docker desktop. At the same time, I have installed Olama in my local Windows and configured the host= http://host.docker.internal:11434 , N8n shows that ollama embeddings are successfully connected, but the automatically selected llama3.2 prompts that the value “llama3.2” is not supported! How can I configure the embedding model of ollama to implement Rag? help me!!!
Haha, I solved this problem myself!
Need to pull an embedded model from ollama,I have chosen nominal embedded text
