Hi!
I want to shorten timestamp, which I receive out of previous node. For example i want to use .slice
How should I do it?
{{$json[“timestamp”].slice(-3)}} does not work.
Sorry for dumb question. I am very weak at js.
Hi!
How should I do it?
Hey @roge, welcome to the community!
.slice(-3)
should work fine on strings, so your expression looks good to me:
Is there a chance your timestamp
field isn’t a string? If so, you could try something like {{ $json["timestamp"].toString().slice(-3) }}
Thank you! This one worked well:
{{ $json[“timestamp”].toString().slice(-3) }}
