HR Module Automate
I want to automate hr module i have check in and cehck out if they late send them warning emails in their emails i have all data in google sheet
Hello Muhamed_Ashraf
I hope you are well!
What would you like?
Are you looking for someone to do your flow?
Are you doing the flow and experiencing failure?
What do you need?
Big hug
i want someone to help without money ty.
I understand.
Describe step by step what you need and where you are at the moment.
i am in the very begining and i think make it zapier or make easily
can we talk in discord
I understand.
It can be here in the community, because your question may be shared by others and this contributes to our overall growth.
I ask that when you send your questions, follow the platform’s guidelines so that we can understand what you need.
i have the google sheet only
Do you know how to do some things in N8N, like create a flow, insert data, test node… That kind of thing?
no and i am thinking to make this flow in make or zapier what do you think?
please can you help me
or tell me courses to understand n8n
I use only N8N
okay may you help me to understand n8n or give me courses link or help me
I can certainly help you, after all, we are a community that helps each other a lot!
Here you can take 2 courses from N8N itself that will help you a lot.
These courses are completely free.
Here is the link to course 1 - Index | n8n Docs
Here is the link to course 2 - Level two: Introduction | n8n Docs
With these 2 courses, plus the community and your will to learn, I am sure you will achieve great goals.
Remember to help those who also need it, so the community will continue to be strong and vibrant.
Take care, my dear friend!
Hello, could you kindly mark my previous post as the solution (blue box with check mark) so that this ongoing discussion does not distract others who want to find out the answer to the original question? Thanks.
