Hi,
have you an idea to set in the HTTP Header a Keep Alive Setting ?
Connection: keep-alive
My Service need a open connection to send new requests later.
https://en.wikipedia.org/wiki/HTTP_persistent_connection
Regards,
Stefan
Hi,
Regards,
Stefan
Hi again,
my opinion is to send differend parameters to a server.
Login Chunk
Send Parameters Chunk
Logout Chunk
Can i set here this parameters ?
Thanks,
Stefan
Yes, you should be able to set that there. But can not imagine that it then works in the way you expect it to work as there is no mechanism in n8n right now that allows you to send then multiple requests with that single connection or to process the data as it arrives.
I have seen that. Its a thing with the implementation of the http stack. Ill try to use loopback to make this.
