Everytime I try to view the input and output of my HTTP request the entire N8N editor freezes/crashes
The editor either becomes unresponsive and needs to reload to work again, or I get a 503 error.
This is the last part of my workflow. Everything before this part works fine, just when inspecting the input and output of the “Delete file” or “Check if file is deleted” node the editor will crash.
Crashes before I can get the output.
- n8n version: 1.116.2
- Database (default: SQLite): Default
- n8n EXECUTIONS_PROCESS setting (default: own, main): Default
- Running n8n via (Docker, npm, n8n cloud, desktop app): N8N cloud
