HTTP Request POST to GPTs Assistants
I’m trying to access my GPT Assistant using an HTTP Request node in n8n
JSON parameter needs to be valid JSON - I’ve already tried lots of recommendations from different AIs, but nothing worked
assistant_id: “asst_EbQr4qLCgZ9X7zzt1igjJVD0”,
thread: {
messages: [
role: “user”,
content: $json.chatInput
NodeOperationError: JSON parameter needs to be valid JSON at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@[email protected]_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/HttpRequest/V3/HttpRequestV3.node.ts:430:15) at WorkflowExecute.executeNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1265:31) at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1446:22) at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1847:38 at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2461:11
In your POST request, put $json.chatInput inside double brackets and quotation marks.
“{{ $json.chatInput }}”
Also in your GET request there is a false expression. {{thread_id}} will return undefined in this case. If the last node will output a field called “thread_id” then this is the correct expression:
{{ $json.thread_id }}
