hi everyone and thanks for the community
the workflow is after receiving a message in WhatsApp via webhook the workflow is storing the number and send back a message “נשמר” which mean saved in Hebrew
the problem is thet i would like to send the message in Hebrew but i get a response:
request path contains unescaped characters
but when i change it to English it works perfectly
this is the url - in Hebrew
https://app.bot4wa.com/api/send.php?number=1217587569xxx&type=text&message=נשמר&instance_id=609ACF283XXXX&access_token=a2bdfb81XXXXXXXXXd8de9e
this is the url - in English
“https://app.bot4wa.com/api/send.php?number=1217587569xxx&type=text&message=saved&instance_id=609ACF283XXXX&access_token=a2bdfb81XXXXXXXXXd8de9e”
is there a way to send the url with the Hebrew letters?
thank you
