Hello guys.
I am using n8n Docker on ubuntu linux server.
I have installed letsencrypt + duckdns. but my docker containers just open in http.
how do i can use letsencrypt for n8n so i can use it for telegram webhook ? it just only accepts https.
thanks.
n8n version: latest
Database you’re using (default: SQLite): default
Running n8n with the execution process [own(default), main]:
**Running n8n via [Docker, npm, n8n.cloud, desktop app]:**Docker
I did it so long time ago, but I use this nginx config: https://termbin.com/2f9j
The last two certificates had been generated by certbot so remove them and then try to run certbot via sudo certbot
ok let me explain :
i am using https://swizzin.ltd/ for installing jellyfin and some stuff.it installs nginx and duckdns + letencrypt.
i don’t know how to edit nginx conf file.
