Hubspot credential connection issue
Hello guys, first off, thanks for such a wonderful community and support. I have the following issue and would love some assistance here:
Goal: trying to use and connect a Hubspot Oauth or Dev API credential that is needed to sync hubspot CRM platform activities into the destination I want it to flow to(my saas).
what’s needed: a hubspot public app with scopes + above hubspot creds to connect
The issue: after inserting correct info into the credentiaal creation panel on n8n, and after tapping on connect, it shows my account on hubspot, but then leads to an error. the error shows the scopes that that have not been added in the hubspot app, BUT THOSE SCOPES ARE ADDED. so this error does not make sense and it prevents to create the hubspot credential. and without this credential, i cannot have the hubspot activity to flow back to me.
(Select the nodes on your canvas and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste
 the workflow.)
  • n8n version: latest
  • Running n8n via (Docker, npm, n8n cloud, desktop app): self hosted
  • Operating system: imac
Looks like you’re running into a classic OAuth mismatch. Double-check that you’re using the *exact* scopes listed in the HubSpot app’s settings within n8n. Sometimes a tiny typo can cause this. Let me know if this works!
